Author Topic: Transformation Template and Connected Attributes  (Read 4651 times)
adsoyad
« on: October 22, 2013, 05:26:16 am »
I can connect my attributes in a class diagram, but I cannot access these attributes from connection macros using Transformation Template. Is there any way to do that?(Including using an add-in)
Stephane B
Re: Transformation Template and Connected Attribut
« Reply #1 on: October 25, 2013, 06:54:44 pm »
What do you mean by "connect my attributes"? Could you give an example of what you have and what you want to achieve?
Aaron B
« Reply #2 on: October 28, 2013, 09:58:13 am »
If you are referring to the "Link to Element Feature" function (see link below) - I don't think there is any way to handle this in Transformations at the present time.  This feature is only intended as a visual aid and does not actually have any impact upon code generation or transformation at this time.
http://www.sparxsystems.com/enterprise_architect_user_guide/10/modeling_basics/connect_to_element_feature.html
