Author Topic: package.update() exception  (Read 6037 times)
Guillaume
    • www.umlchannel.com
« on: November 19, 2013, 05:43:25 am »
I'm running a loop on a selection of packages from an EA project to update a number of attributes.
To do so, I executed a SQL query to retrieve my packages and loaded them into an XmlNoteList via an XMLDoc.
I'm looping through the XmlNoteList, retrieving the EA.Package based on the guid, updating some attributes, and finally running package.update().
It works for a number of packages until it hits a package that throws the following exception :
StackTrace ... EA.IDualPackage.Update()
-            Keys      {System.Collections.ListDictionaryInternal.NodeKeyValueCollection}      System.Collections.ICollection
Any idea of what's going wrong? Do you need additional info ? (I'm running in debug mode)
thanks
Guillaume
Re: package.update() exception
« Reply #1 on: November 19, 2013, 10:23:12 am »
How does your update code look like? Is it GetPackageByGuid / edit / Update? If so, have you checked the Get returns a valid object?
« Reply #2 on: November 19, 2013, 06:05:45 pm »
Also make sure you run the Project Integrity Check to make sure there are not inconsistencies in the package you are trying to update.
