Author Topic: language data type conversion  (Read 4353 times)
Jakub
« on: November 20, 2013, 03:22:11 am »
Is there a way how to transform a data type from PSM to PIM e.q. in C# there is a type UInt16 which would reffer to int in PIM.
CONVERT_TYPE does this transformation from PIM to PSM
Re: language data type conversion
« Reply #1 on: November 20, 2013, 06:32:43 am »
Just from the stomach my feeling is that transformation was designed for the forward process, not for re-engineering. So the answer is most likely: not possible unless you use some add-in.
« Reply #2 on: November 20, 2013, 09:12:26 am »
If you're writing transform templates to do it then it would look something like this.
%if attType="UInt16"%
 type="int"
%elseIf ... %
%endIf%
Jakub
« Reply #3 on: November 20, 2013, 11:19:42 pm »
thanks!
Is it possible to do a contain operation on string?
something like "Dictionary<String, Shift>".contains("Dictionay")
« Reply #4 on: November 21, 2013, 08:22:53 am »
You'll find FIND on the help page for function macros, but you'll need to do it before the condition and assign it to a variable to check later.
« Last Edit: November 21, 2013, 08:23:27 am by simonm »
Dermot
« Reply #5 on: November 26, 2013, 04:09:22 pm »
Re: Original question - there are some similar scripts available on the Community site for Database PSM->PIM that you might be interested in.
See: http://community.sparxsystems.com/community-resources/512-84data-modeling-logical-and-conceptual-mda-transforms
