Author Topic: Issue during automatic create Documentation Model  (Read 3319 times)
haepeto
« on: December 13, 2013, 03:28:30 am »
I try to create a documentation model using master document containing model document(s).
Everything goes well and works except for the part where I want to SET the name of the RTF Template to use for the master document.
Normally, this should work like this:
    [*] Create a package, set stereotype 'master document', name it
    [*] as the stereotype has a default TaggedValue of type RTFTemplate, look it up
    [*] Set value to name of template (e.g. Master Analysis)
    [*] Update package
    [/list]
    Whatever I tried, setting value, setting notes, setting defaults, ...
    I did not succeed putting the right template in, although this is only two clicks in the EA GUI.
    So, did I hit a bug in EA scripting?
    How should it be done? I prefer to use the EA API.
    Extract from the code, developed as a JScript script:
    function AddMasterDoc(package, sub, diagram, tree)
          var thePackage as EA.Package;
          thePackage = package;
          var subPackageName;
          subPackageName = sub + " " + Repository.GetPackageByID(thePackage.ParentID).Name;
          subPackage = thePackage.Packages.AddNew(subPackageName, "Package");
          subPackage.StereotypeEx = "master document";
          subPackage.TreePos = tree;
          subPackage.Update();
          subPackage.Element.Stereotype = "master document";
          var tag as EA.TaggedValue;
          subPackage.Element.SynchTaggedValues("Core Extensions", "master document");
          tag = subPackage.Element.TaggedValues.GetByName("RTFTemplate");
          if (tag == null)
                tag = subPackage.Element.TaggedValues.AddNew("RTFTemplate", "Master Analysis");
          else
                tag.Value = "Master Analysis";
          // This goes wrong - asked support to help
          tag.Notes = "Default: (model document: master template)";
          if (!tag.Update())
                Session.Prompt("Tag Error: " + tag.GetLastError(), promptOK);
          subPackage.Element.TaggedValues.Refresh();
          if (!subPackage.Update())
                Session.Prompt("MasterDocPackage Error: " + subPackage.GetLastError(), promptOK);
          return subPackage;
