Author Topic: Automation interface: compile error in java code  (Read 4452 times)
bITs.EA
« on: January 03, 2014, 12:51:36 am »
I'm trying to get a package-object from the repository (get by id) and get the package name.
Here's a code snippet:
org.sparx.Package oPackage = null;
oPackage = repo.GetPackageByID(Integer.parseInt(packageID));
String sName = oPackage.Name;
When I run my script, I get the following compile error
deleteExternalRef.java:44: error: cannot find symbol
  symbol:   variable Name
1 error
...Run
What am I doing wrong???
bITs.EA
Re: Automation interface: compile error in java co
« Reply #1 on: January 06, 2014, 07:57:39 pm »
Problem solved: I had to use a method "package.GetName()" instead of a variable "package.Name".
I guess I'm using an old user guide or the user guide isn't up-to-date...
« Reply #2 on: January 06, 2014, 09:43:16 pm »
I think VB and C# use real properties, so you can indeed write
mystring = oPackage.Name or
oPackage.Name = mystringwhereas Java uses getter and setter methods.
So in Java that would be
myString = oPackage.GetName()or
oPackage.SetName(myString)
bITs.EA
« Reply #3 on: January 06, 2014, 11:30:53 pm »
Thanks for the additional info!
Greets
