Author Topic: Generate diagram image  (Read 5607 times)
Tehila1
« on: January 02, 2014, 09:33:44 pm »
Hello!
How can I insert to a generation document an image of an EA diagram via  EA API- and not by template which contains the image as diagram field?
Thanks!
Tehila1
Re: Generate diagram image
« Reply #1 on: January 03, 2014, 01:10:35 am »
Referring to the previous post, I  would like to know also how to get image of interaction and use-case elements.
Thank you!
Dermot
« Reply #2 on: January 03, 2014, 11:56:04 am »
There are a number of ways - but simplest is to use:
PutDiagramImageOnClipboard (string DiagramGUID, long Type)
See the Project Interface Class help page.
Otherwise see the DocumentGenerator Class topic (and use a template).
Tehila1
« Reply #3 on: January 05, 2014, 11:53:46 pm »
Is there a way to paste a diagram image I have already in clipboard to a document via document generator?
Thank you!
Tehila1
« Reply #4 on: January 08, 2014, 10:11:20 pm »
Hello!
How can I bring an interaction or use-case images into a document via EA document generator?
Can I do it with EA API without using a template?
Thank you!
EXploringEA
« Reply #5 on: January 09, 2014, 11:57:43 pm »
Not sure of your requirements but looks like a lot of document generation.  If you are outputting to word suggest you have a look at eaDocX (eaDocX.com) - these guys have been doing it for years could probably do what you want off the shelf. :)
EXploringEA - information, utilities and addins
« Reply #6 on: January 13, 2014, 09:21:54 am »
This question is effectively: "How can I do <anything> without using any of the methods provided for doing it?"
What is the problem with using a template with the diagram image as a field?
