Author Topic: Gererate XML Schema  (Read 4362 times)
KlausPeter
Gererate XML Schema
« on: January 10, 2014, 08:25:19 pm »
my class model that generates the following schema
<?xml version="1.0" encoding="utf-8"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
  <xs:complexType name="Class1">
    <xs:sequence>
      <xs:element ref="int" minOccurs="1" maxOccurs="1"/>
      <xs:element ref="Class2" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="Class2">
    <xs:sequence>
      <xs:element ref="char" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="Configuration">
    <xs:sequence>
      <xs:element ref="xs:string" minOccurs="1" maxOccurs="1"/>
      <xs:element ref="Class1" minOccurs="1" maxOccurs="1"/>
      <xs:element ref="General" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
  <xs:complexType name="General">
    <xs:sequence/>
  </xs:complexType>
  <xs:element name="Configuration" type="Configuration"/>
</xs:schema>
but i need combination of name/type combination instead of ref in elements of complexType's
    <xs:sequence>
      <xs:element name="Adapter" type="int" minOccurs="1" maxOccurs="1"/>
      <xs:element name="Additional" type="Class2" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
    <xs:sequence>
      <xs:element name="Prefix" type="char" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
    <xs:sequence>
      <xs:element name="Version" type="xs:string" minOccurs="1" maxOccurs="1"/>
      <xs:element name="Comm" type="Class1" minOccurs="1" maxOccurs="1"/>
      <xs:element name="General" type="General" minOccurs="1" maxOccurs="1"/>
    </xs:sequence>
  </xs:complexType>
    <xs:sequence/>
  </xs:complexType>
</xs:schema>
Thanks in advance :-)
Re: Gererate XML Schema
« Reply #1 on: January 10, 2014, 09:16:04 pm »
Have you tried to import the xml schema you adjusted to see what EA makes of it?
KlausPeter
« Reply #2 on: January 14, 2014, 03:08:26 am »
i have importet the corrected schema and in this model i can add more types and all types referenced by name and type.
I have compared all settings of association and complex types to my orginal model ... no difference i have found :(
any other suggestion?
