Author Topic: Invoke EA vbscript via Java automation interface ?  (Read 3915 times)
OpenIT Solutions
« on: January 16, 2014, 01:50:49 am »
As you may know the Java automation interface is missing some capability. As a workaround - is it possible to invoke a vbscript defined within Sparx via the Java version of the automation interface ?
I have for example written a vbscript in sparx that uses the DocumentGenerator to produce some complex custom reports. Within sparx the user just runs the script against a selected package to generate the report. We have a Java web app, that currently calls the Project.RunReport command for our simple reports. The Java API doesn't contain the Repository.CreateDocumentGenerator so i cant replicate the complex report generation within the Web App. Hence request above.
Jon.
« Last Edit: January 16, 2014, 09:26:54 pm by openit »
Re: Invoke EA vbscript via Java automation interfa
« Reply #1 on: January 16, 2014, 02:01:16 am »
IIRC it is not possible (though I may be completely wrong here). There was some post from one of the Sparx supporters. The search nowadays works faster so you should have a chance to find it. (Don't blame me if you don't.)
