Author Topic: Export / Import Reference Data  (Read 5319 times)
philchudley
« on: January 16, 2014, 02:48:04 am »
Hi Guys
Does anyone know of an API function that will export (and more importantly) import Reference Data?
Ideally the API function (if one exists) should accessible in Scripting rather than an Extension)
I realise I may be able to process the Reference Data xml file directly in the Script, but I would like an easier way if possible
Cheers
Models are great!
EXploringEA
Re: Export / Import Reference Data
« Reply #1 on: January 16, 2014, 03:25:01 am »
Hi Phil
The only way I've found for doing this is
Repository.CustomCommand("Repository", "ImportRefData", XMLString)
where XMLString contains the raw XML string as created in the file from "Export Reference Data"
Never looked for Export but assume it probably is a string defining the process "ExportRefData" me thinks.
I put some example code a week or so ago on the forum using this command.
EXploringEA - information, utilities and addins
philchudley
« Reply #2 on: January 16, 2014, 03:27:05 am »
Excellent, many thanks another use the undocumented CustomCommand
Cheers
Models are great!
