Author Topic: Sub-shape with 2 parms in shape script  (Read 4595 times)
« on: January 16, 2014, 06:29:15 am »
Someone getting sick of this? Well, I am...
I tried to use sub-shapes with 2 parameters where layoutType="border". It seems that only "N" and "CENTER" produce results, both being the same. Using "S" shows some strange result in the preview, but none at all on the real diagram.
Re: Sub-shape with 2 parms in shape script
« Reply #1 on: January 16, 2014, 10:09:31 am »
Again, it's used in BPMN. If using Border you MUST specify a default height/width.
« Reply #2 on: January 16, 2014, 10:11:53 pm »
Again: no!
shape main {
      layouttype = "border";
 h_align = "left";
      noshadow = "true";
      DefSize(200,100);
      setfillcolor(0,0,255);
 rectangle(0,0,100,100);
 addsubshape("sub","s");
 shape sub {
  setfillcolor(0,255,0);
  ellipse(10,10,90,90);
"n" and "center" place it in the center. Just see what "s" produces :-(
« Reply #3 on: January 17, 2014, 08:48:49 am »
Here's a tip. I am trying to help you. It's not my job to look up the help for you. But you could find the answer in the sub-shapes topic.
  • Border - This requires an additional argument to the addsubshape method to specify which region of the containing shape the sub-shape is to occupy: N, E, S, W or CENTER; each region can only be occupied by one sub-shape
A sub-shape that is assigned to the E or W region must have its preferredwidth attribute specified in its declaration and, similarly, sub-shapes added to N or S must have their preferredheight attribute set; in this case, the values for these attributes are treated as static lengths and do not scale glyphs
« Reply #4 on: January 17, 2014, 10:53:09 am »
I really appreciate what you do, Simon. And you are right: I missed this sentence right below (probably it should be part of the Border paragraph, not one on its own). However, have a look at this example:
You see the preview? Not exactly what the final shape looks like (try omitting either the "S" or "N" and see what happens then). Now further I would expect either of them to occupy only the 50 units, not something like 75.
