Author Topic: Remove MDG Technology Toolbox from Toolbox List  (Read 5790 times)
minna
« on: January 20, 2014, 07:40:29 pm »
I used Profiles to create a custom toolbox and imported it as an MDG technology. When I click on the 'More Tools' option (part of the Toolbox view) I can select my custom toolbox and use it as required.
My question is, how can I remove my custom toolbox from the 'More Tools' list? I don't need it any more and the diagram that uses it is already deleted.
Minna
Re: Remove MDG Technology Toolbox from Toolbox Lis
« Reply #1 on: January 20, 2014, 07:58:28 pm »
Click the More Tools in the diagram toolbox. On the bottom you find a Toolbox Visibility.
minna
« Reply #2 on: January 20, 2014, 08:01:29 pm »
Thanks, this really helps not to see it in the Toolbox list.
But it is only hidden now. Is there any way to delete or remove the MDG technology from EA?
Minrie
Uffe
« Reply #3 on: January 20, 2014, 09:04:48 pm »
Depends. Or I should say Yes, but it depends. How did you deploy the MDG Technology? There are a couple of different ways of doing that.
« Reply #4 on: January 20, 2014, 09:21:06 pm »
If you de-select it from Settings/MDG Tech it should also go away.
minna
« Reply #5 on: January 20, 2014, 10:18:36 pm »
Great, thank you
