Author Topic: Add seperator in addin menu?  (Read 7553 times)
Sorno
« on: February 14, 2014, 12:17:51 am »
How do I add a horizontal seperator in the addin menu?
It's not mentioned in the documentation regarding "EA_GetMenuItems" or "Define Menu Items".
Thanks!
Re: Add seperator in addin menu?
« Reply #1 on: February 14, 2014, 01:02:23 am »
IIRC you have to return "-" as menu name.
See also http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1364887854/2#2
« Last Edit: February 14, 2014, 01:04:18 am by Geert.Bellekens »
Sorno
« Reply #2 on: February 14, 2014, 01:47:02 am »
Thank you!
I tried with - before but as in "&-". Which reminds me that I don't know why do the other strings begin with &?
I feel silly each time this happens in the forum. When I search for "seperator" nothing turns up.  And I do use the proper search page, and not the right hand field. I missed the option "This post was made in the last... week"  ::)
Thank you again,
Jonas
« Last Edit: February 14, 2014, 02:10:48 am by Sorno »
« Reply #3 on: February 14, 2014, 02:48:19 am »
It's not you being silly. There is this Search button which leads you to a very dumb search page. Plus the "Search the forum" which does not return anything at all. Plus (!) the "Search..." on top of this which will make confusion perfect.
« Reply #4 on: February 14, 2014, 08:42:21 am »
You put the & in front of the letter that you want to be the shortcut key. So "Short&cut" would appear as "Shortcut" and pressing 'c' will execute the command if the menu has focus.
« Reply #5 on: February 14, 2014, 05:36:29 pm »
Ha, I didn't know that either, thanks KP :)
Sorno
« Reply #6 on: February 14, 2014, 07:13:40 pm »
Many thanks!
Aaron B
« Reply #7 on: February 17, 2014, 10:32:34 am »
Just for further reference regarding the "&" within the menu item text, this is called a Mnemonic Key and is a pretty standard practice to help with keyboard navigation.  See:
http://msdn.microsoft.com/en-us/library/aa233545%28v=vs.60%29.aspx
http://en.wikipedia.org/wiki/Mnemonics_%28keyboard%29
