Author Topic: Custom properties - Update Value  (Read 3363 times)
Dalia
« on: February 20, 2014, 11:46:46 pm »
Hi all,
I've been trying to add parameters to an InfrastructureService.
To do that I've implemented the following function to create the activityParameter and to update the direction property value. direction is an input parameter to this function and can have the values in/out/inout.
function AddParameter (objparent, nome, direction)
      set parm = nothing
      if objparent is nothing then
            set parm = objparent.Elements.AddNew(nome, "ActivityParameter")
            parm.update()
            for each c in parm.customproperties
                  if strcomp(c.name, "direction")=0 then
                              c.value = direction
                  end if
            next
            parm.update()
      end if
      set AddParameter = parm
end function
What I state calling this function is that the direction parameter always assumes the last set value independently of the ActivityParameter being created/manipulate. For instance, after executing the following code
      set theParameter = AddParameter (root, "teste1", "in")
      set theParameter = AddParameter (root, "teste2", "out")
      set theParameter = AddParameter (root, "teste3", "inout")
      set theParameter = AddParameter (root, "teste4", "inout")
teste1, teste2, teste3 and teste4 all have the "inout" value in the direction parameter.
I've tested this in version 10 and 11.
Can you please help?
Dalia
Re: Custom properties - Update Value
« Reply #1 on: February 21, 2014, 01:52:30 am »
In the mean time I changed the function to the one below an it is working not being sure why did it start to work.
      set parm = nothing
      if not (objparent is nothing) then
            parm.update()
                              c.value = direction
                  end if
            next
            if not(parm.update()) then
                        session.output "error"
            end if
      end if
end function
« Reply #2 on: February 21, 2014, 01:55:23 am »
I just tried it and had no problem. So likely you must be doing something wrong. Likely it's something in that hidden AddParameter method.
P.S. So I was right  ;D
« Last Edit: February 21, 2014, 01:56:15 am by qwerty »
