Author Topic: ShowInProjectView from VBA  (Read 7732 times)
rossi
« on: February 24, 2014, 11:29:40 pm »
I wrote a script in VB to access elements of my EA model and select an element in the project browser. It works well.
Now I try this from Excel with VBA.
GetElementByGuid() works, but ShowInProjectView() breaks the script.
Is it possible to do this from Excel?
Dim myElem As EA.Element
Set myElem = Repository.GetElementByGuid("{AD.....1B}")
Repository.ShowInProjectView(myElem)
thanks
Rossi.
« Last Edit: February 24, 2014, 11:30:26 pm by rossi »
Re: ShowInProjectView from VBA
« Reply #1 on: February 25, 2014, 01:45:17 am »
You need to access the EA instance. There's something like
Set EAapp = GetObject(, "EA.App")
Set Repository = EAapp.repository
you need to prepend.
rossi
« Reply #2 on: February 25, 2014, 02:20:06 am »
Thank you, unfortunately it doesn't work.
The ConnectionString points to the correct repository and the call of GetElementByGuid() returns a correct value.
But ShowInProjectView() jumps to the error label.
Any further ideas?
« Reply #3 on: February 25, 2014, 03:42:18 am »
I just tried with a Perl script and that worked. Maybe it's a VB issue?
rossi
« Reply #4 on: February 25, 2014, 10:20:57 am »
It seems so.
I tried with ActivePython and that was working too.
I'm not an expert of VBA, but can it be a problem in the type conversion (from Element to Object)?
« Reply #5 on: February 25, 2014, 11:10:42 am »
Well, I used VB some time as long as there a) was no alternative and b) it worked with no issues. So I'm out ;-)
q,
« Reply #6 on: February 25, 2014, 05:45:39 pm »
What does the error say?
Even in VBA you have some kind of error information.
It could be a type issue.
In C# I use this code. Notice that the type of item is object.
// for all other items we can only select them on the project browser
                    // get the element based on the type and the id
                    object item = getEAObjectByID(type, ID);
                    //show the item in the project view
                    if (item != null)
                        this.wrappedModel.ShowInProjectView(item);
                        return EAWrapperFactory.createEAWrapper(this, item);
                    else
                        // the item was not found
                        throw new Exception("Could not find a " + type + " with id " + ID);
rossi
« Reply #7 on: February 25, 2014, 06:21:19 pm »
Now I have an error code:
"Object doesn't support this property or method"
Of what type should the parameter of ShowInProjectView() in VBA be?
'Object'? Or is there a particular EA type?
« Reply #8 on: February 25, 2014, 06:47:14 pm »
the documentation says object
« Reply #9 on: February 25, 2014, 09:10:38 pm »
If I read above code correctly it *is* an object (EA.Element) being supplied  :-/
« Reply #10 on: February 25, 2014, 10:43:41 pm »
I'm just thinking; if its not the type issue (EA.Element vs object) it might just be that VBA doesn't like the parentheses
You might need to write
Repository.ShowInProjectView myEleminstead of
Ah, the lovely VBA syntax :P
rossi
« Reply #11 on: February 25, 2014, 11:18:45 pm »
Thanks a lot Geert!!!
Now it works  :)
