Author Topic: Change element's appearance background color  (Read 8945 times)
gandel
« on: February 26, 2014, 09:32:05 pm »
I want to change background color of an element (class or use case) to a given RGB color. How can I make this (with script)?
Thank you in advance
Re: Change element's appearance background color
« Reply #1 on: February 26, 2014, 10:58:45 pm »
Check Element.Setappearance in the help.
gandel
« Reply #2 on: February 26, 2014, 11:16:32 pm »
Thanks, it works:
myElement.SetAppearance(1,0,color);//color is RGB number
myElement.Update();
2pointO
« Reply #3 on: February 04, 2016, 07:33:44 pm »
I also want to set the appearance of an element via a VBA Script which automatically creates component out of an excel sheet I used :
myElement.SetAppearance(1,0,255)
myElement.Update
parentPackage.elements.Refresh
and when I try to run the script I get the error : Error while compiling , syntax error , expected =    (translated)
VBA doens't need the ; at the end , I have mutliple methodes in that script that work fine with the syntax but here it asked me to set a "=" for what?
Thank you
« Reply #4 on: February 04, 2016, 07:47:51 pm »
try
myElement.SetAppearance 1,0,255
2pointO
« Reply #5 on: February 04, 2016, 08:18:41 pm »
Works, thank you :)
Sarah
