Author Topic: Failed to open EA in Jenkins build: error 80080005  (Read 11508 times)
koenemann
« on: February 24, 2014, 09:58:49 pm »
We would like to call the EA from a Jenkins build job, but that fails when creating an instance of Repository.
Stacktrace when running from DLL (unfortunately only in German):
Die COM-Klassenfactory für die Komponente mit CLSID {67F4E0FA-46A7-4255-B084-69A9433D08C3} konnte aufgrund des folgenden Fehlers nicht abgerufen werden: 80080005 Starten des Servers fehlgeschlagen (Ausnahme von HRESULT: 0x80080005 (CO_E_SERVER_EXEC_FAILURE)).    bei System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   bei System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache)
   bei System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean skipCheckThis, Boolean fillCache)
   bei System.Activator.CreateInstance(Type type, Boolean nonPublic)
Stacktrace when running from Java:
java.lang.Exception: Failed to construct object. Error code: 0x80080005
      at org.sparx.Repository.comConstructor(Native Method)
      at org.sparx.Repository.<init>(Repository.java:170)
The EA is installed and can be started manually with the same user the build job is running with.
Any idea what could be missing?
« Last Edit: February 24, 2014, 11:04:50 pm by koenemann »
Re: Failed to open EA in Jenkins build: error 8008
« Reply #1 on: February 24, 2014, 11:05:39 pm »
I don't have much ideas about Java, but there were some threads about creating an EA instance via Java. Try the Search button top left.
koenemann
« Reply #2 on: February 24, 2014, 11:13:49 pm »
Thanks for the quick reply.
It does work to create the Repository object when running the application manually (both via DLL and via Java). So I assume our code is fine. But it does not work inside a Jenkins build job, apparently because a COM class a CLSID that is probably from the EA interop dll is not registered. But why is that different from running it manually?
Any idea?
OpenIT Solutions
« Reply #3 on: February 25, 2014, 05:04:14 am »
Its probably a PATH or CLASSPATH issue. Is Jenkins using the same JRE/Java instance ? Assume you have added eaapi.jar onto the classpath used by Jenkins and that SSJavaCOM.dll is on the PATH ? I typically just add the SSJavaCOM.dll to the bin folder of my JRE/Java runtime....
koenemann
« Reply #4 on: February 25, 2014, 05:11:40 am »
Thanks for the reply, unfortunately the classpath and library path are ok:
  • eaapi.jar is on the classpath (otherwise we would not reach the constructor of the Repository class).
  • SSJavaCOM.dll is on the library path, otherwise we get a java.lang.UnsatisfiedLinkError: no SSJavaCOM in java.library.path
« Reply #5 on: February 25, 2014, 08:12:42 am »
You should in parallel contact Sparx support.  Maybe they can help.
« Reply #6 on: February 25, 2014, 08:56:20 am »
Problems I remember for EA in a batch job.
1. No EA key - Launch EA from that user account with GUI to add a key.
2. User has no permissions to create COM objects.
koenemann
Re: Failed to open EA in Jenkins build [solved]
« Reply #7 on: February 27, 2014, 07:54:23 pm »
Thanks for the reply! The user permissions were indeed wrong. More precisely, the jenkins build ran with a different user than expected which did not have the permissions.
Boron
Re: Failed to open EA in Jenkins build: error 80080005
« Reply #8 on: November 28, 2019, 01:35:20 am »
Sorry for warming up this really old topic, but I run now into are quite similar problem.
If I refer to the last two post right before this one.
1. This is a "Passed". Our "Jenkins user account" has an EA license. Being logged in as that user and starting the EA GUI works without any problems.
2. This is probably a "Failed". How can I find out if the user has the right to create COM objects?
Many thanks.
