Author Topic: Code Template : String processing  (Read 4446 times)
Dobrin
« on: March 24, 2014, 08:19:05 pm »
Hello all,
I have a question regarding the Function Macros from Code Template.
Is it possible to process the string in a way to change the order of some sub-strings?
e.g :
$myString = "substring1,  substring2, substring3"
%SOME_FUNCTIONS($myString)%
After this processing the string will be :
$myString = "substring3,  substring2, substring1"
Is it possible to obtain this?
Thank you in advance for you answer!
Gruß
Dobrin
webfox
Re: Code Template : String processing
« Reply #1 on: March 24, 2014, 09:23:41 pm »
I don't think it is. One thing you could do is write your own custom add-in implementing additional string manipulation as you require. You can then call your add-in from within a template using the following syntax:
$result = %EXEC_ADD_IN("AddInName","MethodName", Parameter1, Parameter2, ..., ParameterN)%
Information on add-in development can be found here: http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/addins_2.html.
Cheers,
Till
