Author Topic: Default diagram type for Objects/Instances  (Read 7950 times)
martin1
« on: April 01, 2014, 04:59:20 pm »
I know how to set the default diagram type for stereotypes (using the _defaultDiagramType attribute). Is there a way to specify the default diagram type for objects/instances created from my stereotypes? Currently this defaults to a "composite structure diagram".
Martin
Re: Default diagram type for Objects/Instances
« Reply #1 on: April 01, 2014, 08:04:37 pm »
Check the _defaultDiagramType property.
martin1
« Reply #2 on: April 01, 2014, 09:36:35 pm »
Thanks, but how do I apply this to objects/instances?
« Reply #3 on: April 02, 2014, 12:24:52 am »
Oh, I see you already mentioned the property in your OP  :-[
Can't you apply this to an Object metaclass in your MDG?
martin1
« Reply #4 on: April 02, 2014, 05:26:00 pm »
I already thought of doing so, but how do I relate the object metaclass to my stereotype? Just creating an object metaclass with the _defaultDiagramType attribute in my stereotype profile does not seem to be sufficient.
Martin
« Reply #5 on: April 02, 2014, 07:48:04 pm »
Your stereotype must extend Class and Object metaclasses. That should do.
P.S. I found this bug report from 2010 in my mail:
EA Version:  7.5.850
EA Edition:  Corporate Floating
EA Add In:  No Add-In
Repository Type:  MySQL
Operating System:  Windows XP
Service Pack:  2
ISSUE DETAILS
Subject:
_defaultDiagramType not inherited
Details:
I have another issue with the MDG file. My metaclass has a
_defaultDiagramType which works correctly for extending stereotypes. In
my case I have an abstract stereotype Device which inherits to a couple
of other stereotypes (like DEV Display etc.). When I create a composite
diagram for the latter these are of type CompositeDiagram. So they do
not inherit the _defaultDiagramType.
and the last response
Hi Thomas,
Thank you for your note.
This behaviour is being investigated and we will provide you with a
further response as soon as possible.  Your reference number for this
enquiry is 10086625.
Best Regards,
Simon Cotching
« Last Edit: April 02, 2014, 07:53:06 pm by qwerty »
martin1
« Reply #6 on: April 02, 2014, 11:47:56 pm »
Thanks, I checked that out, doesn't work. Maybe I did something wrong or the bug from 2010 is still in effect.
Martin
« Reply #7 on: April 03, 2014, 12:32:05 am »
I would have a look into your profile if it is not confidential.
martin1
« Reply #8 on: April 03, 2014, 04:03:25 pm »
Thanks for your offer, but right now I cannot share it.
