Author Topic: EA_OnPostNewElement and nested elements  (Read 11936 times)
Sorno
« on: April 03, 2014, 07:58:50 pm »
In my addin I use EA_OnPostNewElement to automatically set stereotype and name of certain elements that are either invocation and property.  I have a few issues though with elements created as property.
First issue:
The  EA_OnPostNewElement is called twice, first without information of PropertyType (the value is 0). Then the dialog is shown and after that EA_OnPostNewElement is called for the second time (now with PropertyType set to correct elementID). Since I don't have the PropertyType the first time I can't identify the kind of element that is created and suppress the dialog accordingly.
Second issue:
If the new element (created as propety) is created as a subelement (dragged and dropped on a existing element) it's name isn't updated in the diagram nor in the browser. The stereotype is changed though. I find this odd since I change them at the same time.
Edit: In this case the  EA_OnPostNewElement is not called at first, instead the user dialog is shown and afterwards EA call EA_OnPostNewElement.
element.Stereotype = "UsedConfiguration";
element.Name = propertyType.Name;
element.Update();
Using EA 10.1009.
Thank you for your input!
Jonas
« Last Edit: April 03, 2014, 08:15:50 pm by Sorno »
