Author Topic: EA_OnPostNewDiagramObject not called...  (Read 6288 times)
Lars J.
« on: April 02, 2014, 12:39:38 am »
Dear,
I try to intercept the creation of a diagram object using EA_OnPostNewDiagramObject. The signature of the function is:
public bool EA_OnPostNewDiagramObject(EA.Repository r, EA.EventProperties eP)
    return true;  // just a test
But when I set a breakpoint in this method and create a new element of a stereotyped class (that I provided in a uml profile) then the breakpoint is not hit. It is only hit, when I create a standard class on the diagram.
Can I make EA call this hook anyway? Did I miss something?
thanks and regards.
Lars
Lars J.
Re: EA_OnPostNewDiagramObject not called...
« Reply #1 on: April 02, 2014, 12:51:25 am »
Found a workaround:
EA_OnPostNewElement does the trick.
thx.
Lars
« Reply #2 on: April 02, 2014, 01:02:32 am »
I have not tried it, but would say that on creating a new element on a diagram should trigger both hooks. First NewElement then NewDiagramObject.
[edit] Just tried it (V11) and it works as described above.
« Last Edit: April 02, 2014, 01:26:09 am by qwerty »
Lars J.
« Reply #3 on: April 03, 2014, 07:50:49 pm »
qwerty, thx for trying.
I also double checked. EA_OnPostNewElement is hit, EA_OnPostNewDiagramObject not.
I am using EA 10 ultimate. probably I am something missing.....
L.
« Reply #4 on: April 03, 2014, 10:36:08 pm »
I also tried with an BPMN element and no issue too. Same with V10. So you must be doing something wrong.
P.S. Just found out that a Port only triggers NewElement. I'd rate this a bug. Any takers to submit a report? I'm sick of that.
« Last Edit: April 03, 2014, 10:40:55 pm by qwerty »
