Author Topic: New status for Maintenance Issues and Defects  (Read 5726 times)
JdBAlten
« on: April 14, 2014, 09:55:47 pm »
The reference data enables the configuration of several enumerations, e.g. the set of status values for a Requirement.
For Maintenance Issues and Defects however, I cannot find any reference data to modify.
Currently EA (V10.0.1003) supports the values "New", "Verified" and "Complete". I would like to add the value "In Progress" (or similar).
Can some one point me how to add a new status value for Maintenance Issues and Defects?
Re: New status for Maintenance Issues and Defects
« Reply #1 on: April 14, 2014, 11:04:25 pm »
Settings/Project Types/General/Status applies for all elements.
JdBAlten
« Reply #2 on: April 14, 2014, 11:18:27 pm »
Thanks for this quick reaction.
However, I don't think this works as that list contains the values "Approved", "Implemented", "Mandatory", "Proposed" and "Validated", which is different from the list for Maintenance Issues (see question above).
Furthermore, when I would like to configure the auto-number feature for Maintenance Issues, I need to check the "Obj-Issue" type instead of "Issue" (using menu Settings => Auto Names and Counters).
The settings mentioned allow to apply that list for more objects via the button "Applies to...". In this list, the value "Obj-Issue" is missing. And neither "Issue" nor "Object" seems to do the trick.  :(
« Reply #3 on: April 15, 2014, 12:18:44 am »
When I create an Maintenance/Issue element from that toolbox I see the above noted status list. So which toolbox do you use to get something different?
JdBAlten
« Reply #4 on: April 15, 2014, 01:14:51 am »
The Issues I'm talking about are generated as follows:
  • Create a TestSet element.
  • Create a test in the TestSet.
  • Create a defect from the test generated.
The tests can be shown via the Element => Testing window ("Alt+3").
The defects can be shown via the Element => Maintenance window ("Alt+4").
« Reply #5 on: April 15, 2014, 03:36:14 am »
So you're not talking about elements but some EA funny wizardry. I don't use that. Sorry.
Nizam Mohamed
« Reply #6 on: April 15, 2014, 02:26:36 pm »
The status messages in the maintenance tab (defects) should also be customizable, please report as a feature request / bug report.
But we usually create a change / issue item from the maintenance item (right click -> Create as a new element) , which will
  • Allow customized status to be maintained
  • Maintain better traceability (as an implicit dependency is created
  • Also use visual cues / status color for the defects in the model
