Author Topic: Operations and functions without Addin's?  (Read 5143 times)
MathiasK
« on: April 14, 2014, 05:24:20 pm »
Hi Sparks Community,
iam a student apprentice and very new to UML and newbie at EA.
Story:
I try to make some operations that can collect and select elements:
GetType, GetAllOperations, GetAttributes, GetAllOwnedElements, GetName, SelectByClassifier, Flatten, ToSet, SelectBySterotype, SelectByStartWithNumber, SetColorTo and so on.
also combine them , and may color the elements wich are selected.
Problem:
I first tried to start with "Addins" with that great tutorial of mr. bellekens.
I hadn't the rights for the registry and probably won't have them in the future.
Is there way to do the operations in some scripts or other methodes/scripting languages ?
Maybe with VBScripts or JScripts ?
I would be very pleased if you could give me some hints on my questions.  :)
Best wishes
Mathias
« Last Edit: April 14, 2014, 07:12:13 pm by mathaiskrill »
Helmut Ortmann
Re: Operations and functions without Addin's?
« Reply #1 on: April 14, 2014, 07:25:51 pm »
Hello Mathias,
EA support both VBScript and JScript. If you select :
Settings, MDG Technology, EAScriptLib
you will find valuable examples for scripts.
Helmut
« Reply #2 on: April 14, 2014, 07:28:13 pm »
Check Tools/Scripting. You can write on-the-fly scripts in JScript and VB Script. It's also possible to run scripts externally using EA's API where you could utilize a variety of programming languages.
MathiasK
« Reply #3 on: April 14, 2014, 07:33:20 pm »
Thank you Helmut and qwerty !
Do you know may the following:
1. Access to the EA Gui or UI for new Windows ?
2. Is there a scripting engine for c# ?
3. Any Python engine mayby?
Best wishes
Mathias
« Last Edit: April 14, 2014, 07:35:24 pm by mathaiskrill »
Helmut Ortmann
« Reply #4 on: April 14, 2014, 08:58:24 pm »
You can use every language which support Windows COM.
There isn't a lot in the EA API to access EA GUI.
I don't know of any scripting environment for C#. You can use C# without a scripting environment.
Helmut
« Reply #5 on: April 14, 2014, 09:38:56 pm »
You can use Python. You can find a sample in my Scripting book (also in the free sample). I'd touch C# only with pliers, but Geert Bellekens has a lot of C# stuff available for the public.
MathiasK
« Reply #6 on: April 15, 2014, 11:13:34 pm »
thank you for your help qwerty
