Author Topic: DOORS MGD  (Read 6435 times)
jimbo
DOORS MGD
« on: April 24, 2014, 08:51:05 am »
If we are using the DOORS MGD Link. When we do a Synchronization of imported DOORS® modules I assume we will not loose any links we made in EA.
What EA use as it's Key/ID from DOORS to EA. Is it in the t_connector table or t_object table?
~J
Aaron B
Re: DOORS MGD
« Reply #1 on: April 24, 2014, 09:47:42 am »
Correct.  Any relationships you define in EA between your imported requirements and other elements should remain after performing synchronization.  Just from memory - I think it saves an "Object Identifier" tagged value on each requirement which corresponds to the object id in DOORS.  If a matching Object Identifier tag is found in EA, it synchronizes with that element, if not found, a new requirement element is created.
Element tagged values are stored in t_objectproperties.
jimbo
Re: DOORS MGD
« Reply #2 on: April 25, 2014, 09:36:59 am »
Do either the DOORS Absolute Number or the DOORS Object Identifier need to be mapped for the sync to work? Or does EA do the mapping in the background?
~J
Nizam Mohamed
Re: DOORS MGD
« Reply #3 on: April 25, 2014, 02:06:51 pm »
DOORS MDG Link takes care of creating the required Object Identifiers. AFAIK the mapping is only for requirement's attributes.
