Author Topic: "Select" project elements verifying a co  (Read 14989 times)
JP
« on: August 06, 2004, 02:40:55 am »
Is there a way to extract from the whole project tree structure elements verifying a specific condition based on (but not limited to) their attributes values, such as, for instance, "Status" field = "Validated". Idealy I would view these elements in th esame tree structure but with a different color.
More generaly is there a way to run (SQL ?) queries on the DB tables of the project (since the whole thing is a bunch of Access DB tables).
I assume this should be possible using Automation but I was wondering if there would be an already built in tool/function to do that.
I have a really big project and I need to be able to extract / view the elements or diagrams that have been "validated" or not by others.
JP
Re: "Select" project elements verifying
« Reply #1 on: August 11, 2004, 03:33:53 am »
(quite shure I already posted something here ???)
JP,
you can issue a query. The table in question is t_object where you should find everything you need.
« Last Edit: August 11, 2004, 03:35:21 am by thomaskilian »
