Author Topic: problems using " EXEC_ADD_IN "  (Read 4453 times)
bachus
« on: May 07, 2014, 12:22:00 am »
Hello everyone,
I struggling on this for a few days.
Using the Code template editor, I've seen that its possible to call an add-in function.
I have already made my personal add-in in C#, and it is correctly installed.
My function is just returning a string (to check if it was working...)
public string invert_string(EA.Repository ElementfromEA, String string_to_invert)
            string_to_invert = "inside";
            return string_to_invert;
In EA I'm calling it like this:
$tmp = %EXEC_ADD_IN("my_addin", "invert_string", "")%
Then generating the code, I got an error:  invert_string: Invalid Parameter(s)
Can you give me an hint on how to make it work ?
Or an example ?
Best regards
Tehila1
Re: problems using " EXEC_ADD_IN "
« Reply #1 on: May 07, 2014, 12:43:22 am »
Two quesions please:
1. Why do you send three strings to the method?
    The method signature requires two arguments.
2. Why do you send a string as the first parameter? As far as I understand you ought to sent a repository, not a string.
Hope this help, please update.
« Last Edit: May 07, 2014, 12:56:04 am by avoda234 »
« Reply #2 on: May 07, 2014, 02:01:40 am »
The parameters are ok. See here: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1395652745/1#1
So it must be something else.
I once used it, but it's too long ago.
Aaron B
« Reply #3 on: May 07, 2014, 09:42:23 am »
The problem is the method signature in your C# code.  See:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1367966852/1#1
Nizam Mohamed
« Reply #4 on: May 07, 2014, 03:18:05 pm »
Sample method, and addin call for your refernce
public string GetObjectType(EA.Repository Repository, object args)
                /* Decode Arguments */
                ArrayList ary = new ArrayList((ICollection)args);
                if (ary.Count < 1)
                    return "";
                string sConnGUID = ary[0].ToString();
Addin- Call
$result = %EXEC_ADD_IN("MyAddin","GetObjectType",$GUID)%
bachus
« Reply #5 on: May 08, 2014, 12:41:56 am »
Thank you !
It is now working
Best regards
