Author Topic: Create List of Diagrams an Object is in  (Read 4245 times)
Curtis
« on: May 13, 2014, 08:22:18 am »
I've been trying to create a SQL query to create a comma separated list of where each object appears in a diagram. Here's what I have so far:
SELECT t_object.Object_ID, t_object.Name, t_diagram.Name
FROM (t_diagramobjects
LEFT JOIN t_object ON t_diagramobjects.Object_ID = t_object.Object_ID)
LEFT JOIN  t_diagram ON t_diagramobjects.Diagram_ID = t_diagram.Diagram_ID
ORDER BY t_object.Object_ID
I tried using examples such as http://stackoverflow.com/questions/12668528/sql-server-group-by-clause-to-get-comma-separated-values to no avail.
Any help would be appreciated. Thanks!
smendonc
  • I love YaBB 1 Gold!
Re: Create List of Diagrams an Object is in
« Reply #1 on: May 13, 2014, 10:57:49 am »
The below should do what I think you are looking for.  The string concatenation ('+') and case statement are specific to SQL Server.
  • Objects with no names that exist on diagrams represent diagram specific objects like boundaries that may not have been named.
select  cast(o.Object_ID as nvarchar)
         + cast(',' as nvarchar)
         + case when o.Name is null then '' else o.Name end
       + case when d.Name is null then '' else d.Name end 'Object_ID,ObjectName,DiagramName'
  from t_object o
       left join t_diagramobjects do on (do.Object_ID = o.Object_ID)
         left join t_diagram d on (do.Diagram_ID = d.Diagram_ID)
 order by o.Object_ID
