Author Topic: RTF generator: Skip empty rows from custom query?  (Read 5929 times)
Sorno
« on: May 15, 2014, 01:27:05 am »
In EA 10 I'm using the RTF-generator to do a custom SQL query that returns two columns Name and Note of elements. It works alright for all element that both have a name and an non-empty note-field. For the cases where the note-field is empty the RT-generator prints "Note" (the name of the custom field). I presumed it would just skip to write anything if the field was empty.
A ugly-workaround is to set all note-field to atleast contain a empty space, but this also mean that an empty  row is added after each element. Any other way?
Thank you!
« Last Edit: May 15, 2014, 01:27:52 am by Sorno »
Re: RTF generator: Skip empty rows from custom que
« Reply #1 on: May 15, 2014, 08:41:30 am »
If I remember correctly there was an update to the rtf generator to handle empty fields returned from a sql query. Try downloading the latest version and see if that corrects your problem.
(The other alternative is that there was a change provided by a developer but they hadn't thought through the impact and it was sent back to them.)
Sorno
« Reply #2 on: May 15, 2014, 04:45:29 pm »
Ok, thank you for your reply.
I'm using 10.1010, so I guess that feature was sent back to the drawing board. Bummer, I guess I'm out of luck with v.10 then.
Sorno
« Reply #3 on: May 15, 2014, 09:18:02 pm »
In a fragment is it in any way possible to do a SQL query and work with the results as elements, rather than just Custom Field?
I have tried by letting the query return
Select t_object.ea_guid AS CLASSGUID, t_object.Object_Type AS CLASSTYPE but to no use.
My problem:
I want to list elements (from a custom query) and certain elements that they are connected to, but not all. When I set element filters they only seem to be applied to the inital list of elements, not the elements they are connected to.
Any way to filter them as well?
Cheers!
« Reply #4 on: May 16, 2014, 08:44:16 am »
Looks like it was fixed in 11.
SQL query fragments containing empty values will now remove the markers from the generated reports
Sorno
« Reply #5 on: May 17, 2014, 12:50:53 am »
Alright! Too bad we won't be able to upgrade to v.11 for a while...
Thanks for the info and have a nice weekend.
