Author Topic: Limitation of EA's SQL search?  (Read 7871 times)
Sorno
« on: May 17, 2014, 12:30:52 am »
I'm fiddling around with custom SQL for RTF-reporting  and have hit a brick wall.
When trying to use functions like Declare or IF the query returns no data when executed through EA (custom query and sql search). The model is hosted on a Microsoft SQL server och the query works fine if runned directly on the database.
Is this a hard limitation in  EA v10.0.1010?
Have a great weekend!
Re: Limitation of EA's SQL search?
« Reply #1 on: May 17, 2014, 01:53:29 am »
Depends on the RDBMS you use. If you use EAP then you're already in dead end. This Mikeysoft Access complies neither a SQL standard nor does it have any sophisticated functions.
« Reply #2 on: May 19, 2014, 03:46:07 pm »
Sorno,
I'm afraid it is.
Some of the more advanced features of SQL Server don't work when using them through EA.
First time I noticed this was when trying to do a recursive query.
« Reply #3 on: May 19, 2014, 05:04:15 pm »
Generally EA's processing of SQL queries is minimal. Most circumstances I have seen where it failed (but worked with a direct connection) were due to limitations of the drivers.
« Last Edit: May 19, 2014, 05:04:36 pm by simonm »
OpenIT Solutions
« Reply #4 on: May 19, 2014, 09:39:27 pm »
I found that if the statement didn't start with SELECT ... it would fail - so recursive queries in SQL Server for example...the solution we used was to create a VIEW on the SQL Server and issues simple SELCT against the VIEW from Sparx...
