Author Topic: Export and Import of WEB Templates  (Read 14052 times)
ralphtq
« on: August 25, 2004, 02:08:11 pm »
Is there a way to export WEB templates for documentation from one model to reuse in another model through an import  mechanism?
Ralph Hodgson
TopQuadrant
Re: Export and Import of WEB Templates
« Reply #1 on: August 26, 2004, 04:03:11 am »
Not quite shure what kind of templates you mean. But assuming these are a set of classes you can simply export them using XML. Right click the according package and export it. The exported XML file can be reused in any other project.
ralphtq
« Reply #2 on: August 26, 2004, 05:18:56 am »
I am referring to the "Web Style Templates" used for generating HTML - in the Resources Browser.
Ralph Hodgson
TopQuadrant
« Reply #3 on: August 26, 2004, 03:23:45 pm »
You're probably after "Export Reference Data" (under Tools)  Then select "Templates - HTML Style" and "Templates HTML Style Detail".
You then do something similar  with "Import Reference Data" to import it into a new model.
Simon
