Author Topic: Automate Version Control Settings  (Read 20906 times)
Re: Automate Version Control Settings
« Reply #15 on: May 29, 2014, 02:51:56 am »
To update the entry you need to
Repository.Execute ("UPDATE t_genopt ...") with what you need,
Tehila1
« Reply #16 on: June 09, 2014, 08:31:46 pm »
You have to do four things to put a package under version control.
1. Set the unique ID in %APPDATA%\SPARX_Systems\EA\paths.txt
2. Use API VersionControlAdd(..)
3. Set the svn path in registry
    HKEY_CURRENT_USER\Software\SPARX Systems\EA400\EA\Options\VC_SVNExePath
4. svn Timeout in registry (VC_TIMEOUT)
I hope it's all.
Helmut
I followed the instructions above; create a local path via the paths.txt, modify the registry entries.  I also verify that the unique ID is exist in t_genopt.
When I try to add a package to version control via the VersionControlAdd() method, I get the following error: "Could not find connection to version control provider."
What is missing?
Thanks.
« Reply #17 on: June 10, 2014, 01:37:56 am »
Might be a security issue. Have you checked that the user has write access to the VC repo?
Tehila1
« Reply #18 on: June 10, 2014, 05:29:38 pm »
I don't think it is a security issue. When I do this procedure manually- all right.
The configuration is still not set correctly despite the local path exists.
The package control options dialog looks like this:
Version Control : configName: (requires configuration)
File Name : %configName%\packageName.xml
Any ideas?
« Last Edit: June 10, 2014, 05:35:24 pm by avoda234 »
Tehila1
« Reply #19 on: June 16, 2014, 10:23:52 pm »
I hope it's all.
Helmut
There must be something we missed since it still does not work properly.
Is there another registry entry or database value that keeps data for this purpose?
The registry I've modified is the same as manual-defined configurations and I do not see something different.
Thanks in advance!
