Author Topic: integrating EA with eclipse  (Read 4367 times)
Christos
« on: July 03, 2014, 06:08:17 pm »
To whomever it may concern,
Dear Sir/Madam,
I was trying to integrate Enterprise Architect, Ultimate Edition, version 11.0.1107 (Build 1107) without any success.
I tried to follow the instructions on the web-site
http://www.sparxsystems.com/products/mdg/int/eclipse/index.html
, but both Eclipse’s dialog boxes and EA’s dialog boxes are extremely outdated.
Could you please advise on the most recent version of these?
I tried to dig on separate directories and I found that the individual tools have been installed properly. All the relative plug-ins that live under the directory: C:\eclipse\plugins seem fine.
It feels that this is alright.
I believe that the problem comes from EA’s main window. Could you please provide any additional information?
My eclipse configuration is:
Eclipse Java EE IDE for Web Developers.
Version: Kepler Service Release 2
Build id: 20140224-0627
Kind Regards,
Christos
Re: integrating EA with eclipse
« Reply #1 on: July 04, 2014, 08:56:53 am »
First question is are you using the 32bit or 64bit version of Eclipse? It will not work for the 64bit version.
Christos
« Reply #2 on: July 04, 2014, 05:53:50 pm »
Well...... I am using the 64 bit version. There is no way I can get the 32 bit version. What other options have I got left with?
Please make this clear on the respective sections in the manual. I was glad that the most recent version of eclipse is supported, but the 64 bit I thought it should be standard.
On a separate front, it is already too much that EA works on windows only (wine is not considered a "clean" option and it is practically not used)
« Reply #3 on: July 23, 2014, 09:20:51 am »
If you can't use the 32 bit version of eclipse then your option is to just use EA without the eclipse integration.
See the system requirements page for eclipse integration. http://www.sparxsystems.com/products/mdg/int/eclipse/sysreq.html
I understand that you don't like using wine to run an application, but it wouldn't be practical to re-write all of Enterprise Architect without use of any Windows APIs.
