Author Topic: Sorted custom SQL search in a Model Document  (Read 5582 times)
Rudi Claes
« on: August 02, 2014, 01:08:27 am »
Hi all,
I would like to use the following custom SQL search in a Model Document:
SELECT ea_guid AS CLASSGUID, Object_Type AS CLASSTYPE, Name FROM t_object o WHERE stereotype = 'BR' AND Phase = '<Search Term>' ORDER BY Name
However, the sort order is respected in the output window, but not in the generated RTF document.
Any thoughts on this one?
Rudi
Re: Sorted custom SQL search in a Model Document
« Reply #1 on: August 04, 2014, 09:30:36 am »
I believe that the SQL is only used to determine which elements appear. The order of the elements won't be based on your query.
« Reply #2 on: August 04, 2014, 09:36:15 am »
I remember there was a thread with EA not handling the SORT option of a query. ICR whether it was a feature or a bug.
Rudi Claes
« Reply #3 on: August 04, 2014, 11:21:54 pm »
The end-users would like to see the element names in alphabetic order for easy retrieval. Now, the order seems completely random. As this seems a fair question, can this requirement be realized without scripting?
Rudi
« Reply #4 on: August 05, 2014, 12:41:50 am »
Well, the single columns have a sort option. Just click the Name header and you're done. Inconvenient extra click, but it could be worse.
Rudi Claes
« Reply #5 on: August 05, 2014, 09:17:55 pm »
Yes, the sort option on the Name Column of the Model Search is indeed not too much effort. But I would like to use the sorted output of the query in RTF document generation.
« Reply #6 on: August 05, 2014, 09:32:00 pm »
 :-[ The ability to read is a real advantage...
Send a feature request. But don't put much hope in it.
