Author Topic: Hidden properties for Stereotypes  (Read 3269 times)
martin1
« on: August 07, 2014, 12:46:39 am »
Is it possible to add some type of "hidden property" to stereotypes defined in a profile and used in an mdg technology? e.g. something like a version number for example.
It's important that the user of the resulting stereotype cannot modify it and that it can be read using the automation interface.
Any ideas?
Re: Hidden properties for Stereotypes
« Reply #1 on: August 07, 2014, 01:36:29 am »
There's actually nothing offered for that purpose and it has been discussed here formerly. Some came up with mis-using t_xref which should be kind-of save if you don't cross EA's lines directly. Others suggested to add use own tables to the DB which would be a bit safer but would corrupt functions like Project Transfer.
I guess in both cases an XML save/restore would not work.
« Last Edit: August 07, 2014, 01:37:43 am by qwerty »
