Author Topic: EA Project Glossary in the Add-In  (Read 6262 times)
Dobrin
« on: August 07, 2014, 07:48:14 pm »
Hello all,
I want to integrate a Project Glossary in an Add-In. Is that possible?
e.g I have an exported Glossary.xml file and I want to integrate it in the add-in so that it will be available for multiple projects.
Thank you in advance for your answer(s)!
Gruß,
Dobrin
Re: EA Project Glossary in the Add-In
« Reply #1 on: August 07, 2014, 08:59:00 pm »
Yes
You can .
Here's what I use in my Excel importer
' Author:   Geert Bellekens
' Date:     30/04/2013
' Description: adds or updates the Term with the given type,name
'   and meaning in the Glossary.
Public Function addOrUpdateTerm(name As String, termType As String, meaning As String) As EA.Term
    Dim myTerm As EA.Term
    'try to find existing Term with the given name
    Set myTerm = getTermByName(name)
    If myTerm Is Nothing Then
        'no existing Term, create new
        Set myTerm = EARepos.Terms.AddNew(name, termType)
    End If
    'set properties
    myTerm.Type = termType
    myTerm.meaning = meaning
    'save Term
    myTerm.Update
    'refresh glossary collection
    EARepos.Terms.Refresh
    'return Term
    Set addOrUpdateTerm = myTerm
End Function
« Last Edit: August 07, 2014, 09:00:45 pm by Geert.Bellekens »
« Reply #2 on: August 07, 2014, 08:59:03 pm »
You can import the XML via
xmlres = Respository.CustomCommand("Repository", "ImportRefData", sXML);It is also possible to fiddle around with the table t_glossary directly by using Repository.SQLQuery for reading and Repository.Execute for modifying it.
Dobrin
« Reply #3 on: August 07, 2014, 09:32:39 pm »
Thank you guys. I'll try that and keep you posted.
Dobrin.
Dobrin
« Reply #4 on: August 08, 2014, 01:09:43 am »
Dobrin.
I do not know if I have formulated the correct question..
So I only want to install an existing glossary.xml file so that it will be available for all the projects.
Is there any way to do that using C# add-in for EA? Do I have to parse all the file to retrieve the type, meaning, etc... and then create new terms?
Is there a way to call the "Import Reference Data" from Project--> Model Import / Export ?
Dobrin
« Reply #5 on: August 08, 2014, 02:08:12 am »
Sure. It's a menu option. Right where you exported it.
« Last Edit: August 08, 2014, 02:08:45 am by qwerty »
Dobrin
« Reply #6 on: August 08, 2014, 03:37:25 pm »
Yes, that I knwew.
You can acces the EA menu from the Add-in in order to do that each time project is opened (e.g on EA_Connect function)?
Dobrin
« Reply #7 on: August 08, 2014, 06:57:56 pm »
There is no API to control what is in the menus. Just (some/most?) functions are also available via API. E.g. you can import reference data like described above. For other menus you'd need to hack Windoze (IIRC there's a thread where someone described how he did that). You may catch the EA_FileOpen event in order to perform things when a repository is opened.
I wonder if that makes sense for the glossary. It's loaded once and only if a new version is available it should be reloaded. So definitely not at each opening. If you use a shared model it wouldn't make sense anyway.
Dobrin
« Reply #8 on: August 08, 2014, 07:07:13 pm »
So then I could use the above method to import the glossary into the add-in and after that, parse the data in order to add new terms in the dictionary?
Yes the glossary will be loaded once, and then maintained.. so I do not need to do this all the time.
Dobrin
« Reply #9 on: August 08, 2014, 07:57:01 pm »
The method in my first post will read the entire glossary as the Import menu would have done. You supply the XML as string parameter.
« Last Edit: August 08, 2014, 07:57:17 pm by qwerty »
