Author Topic: EA Addin Key Shortcut  (Read 79662 times)
McMannus
Re: EA Addin Key Shortcut
« Reply #15 on: August 07, 2014, 02:30:12 am »
Hi guys,
just to keep you informed about a significant improvement that I discovered during searching the documentation:
The approach for figuring out the currently active application was solved by the background worker thread running infinitely. In the field, this caused ~50% CPU occupation during idle time.
The idea is to solve that by reacting to window events.
Just replace the WndProc method in InvisibleHotkeyForm class with the following code:
       protected override void WndProc(ref Message m)
            if (m.Msg == Hotkey.WM_HOTKEY_MSG_ID)
                foreach (Hotkey key in _hotkeys)
                    if (key.IsPressedKeyCombination(m.LParam))
                        key.Handler();
                        break;
            else if (m.Msg == WM_ACTIVATEAPP || m.Msg == WM_NCACTIVATE)
                bool windowGotFocus = (m.WParam.ToInt32() == 1);
                if (windowGotFocus)
                    RegisterHotKeys();
                else
                    UnregisterHotKeys();
            base.WndProc(ref m);
and at these two constants to the class:
       private const int WM_ACTIVATEAPP = 0x001C;
        private const int WM_NCACTIVATE = 0x0086;
Afterwards the ActiveProcess.cs can be deleted as well as all things that are related to the background worker.
In addition, remove the RegisterHotkeys() call from the OnLoad method.
Jan
« Last Edit: August 07, 2014, 02:31:18 am by McMannus »
Helmut Ortmann
« Reply #16 on: August 07, 2014, 03:37:45 am »
Hi Jan,
thanks a lot.
Could you explain what you mean by 'as well as all things that are related to the background worker'?
Helmut
McMannus
« Reply #17 on: August 07, 2014, 05:15:43 am »
public partial class InvisibleHotKeyForm : Form
        private readonly IEnumerable<Hotkey> _hotkeys;
        private readonly IDualRepository _rep;
        public InvisibleHotKeyForm(IEnumerable<Hotkey> hotkeys, IDualRepository rep)
            InitializeComponent();
            _hotkeys = hotkeys;
            _rep = rep;
            Closing += (sender, eventArgs) => ((List<Hotkey>) _hotkeys).ForEach(key => key.Dispose());
        protected override void OnLoad(EventArgs e)
            Visible = false;
            ShowInTaskbar = false;
            base.OnLoad(e);
                        key.Handler();
                        break;
                if (windowGotFocus)
                    RegisterHotKeys();
                else
        private void UnregisterHotKeys()
            if (!_hotkeys.Any()) return;
                key.Unregister();
        private void RegisterHotKeys()
                try
                    key.Register(window: this);
                catch (GlobalHotkeyException exc)
                    Debug.WriteLine(exc.Message);
Helmut Ortmann
« Reply #18 on: August 09, 2014, 06:43:41 pm »
Hi Jan,
thanks a lot.
It works!
Helmut
avanzwol
