Author Topic: Addins sub-menus  (Read 4469 times)
Tehila1
Addins sub-menus
« on: August 10, 2014, 09:28:11 pm »
I would like to create third-level sub-menus to the addin menu.
The following code creates one menu under Extensions, and under it, one level of sub-menus.
//Addin menu
private const string mainAddinMenuName = "-&Addin menu name";
//The sub-menus
private const string SVNConfigurationMenu = "&sub-menu 1";
private const string SVNClearDataMenu = "&sub-menu 2";
//Initialize the addins menus in the right order
this.menuHeader = mainAddinMenuName;
this.menuOptions = new string[] { sub-menu 1, sub-menu 2};
Is it possible to add more sub-menus under the existing ones?
ZuluTen
Re: Addins sub-menus
« Reply #1 on: August 10, 2014, 10:28:11 pm »
Yes, I've got three 'layers' of menus, and different ones for Diagram, Menu and Tree.
If you look at the EA_GetMenuItems instruction in the Manual you'll see an example.
The following is Sparx' own construct which you'll see puts Menus 5 and 6 in layer 3:
   Public Function EA_GetMenuItems(ByVal Repository As EA.Repository, ByVal Location As String, ByVal MenuName As String) As Object
        Select Case MenuName
            Case ""
                EA_GetMenuItems = "-&VBNet Addin Framework"
                Exit Function
            Case "-&VBNet Addin Framework"
                EA_GetMenuItems = New String() {"Menu1", "Menu2", "Menu3", "-Menu4", "-", "Show Output", "About..."}
                Exit Function
            Case "-Menu4"
                EA_GetMenuItems = New String() {"Menu5", "Menu6"}
                Exit Function
        End Select
        EA_GetMenuItems = ""
    End Function
« Last Edit: August 10, 2014, 10:29:11 pm by ZuluTen »
