Author Topic: Import image from Enterprise Architect to ms Word  (Read 11196 times)
Stenvang
« on: August 18, 2014, 07:55:13 pm »
Working on an Enterprise Architect add-in I want to import an image from Enterprise Architect to ms Word using c#. For now I have solved this by saving the diagram/image as a .pdf file and then reading it again using the iTextSharp.
It seems to me that this is the hard way around the problem and therefore I think there must be a more simple way to get the image from Enterprise Architect to ms Word using c#.
Re: Import image from Enterprise Architect to ms W
« Reply #1 on: August 19, 2014, 01:25:31 am »
No. That's actually the EA way to go.
AndyJ
  • It's only a model
« Reply #2 on: August 19, 2014, 09:10:51 am »
In user-land, it's just Ctrl-A, Ctrl-C, (change focus to the word document) Ctrl-V...
I'm surprised that you need to generate a .pdf file in scripting-land.
Of course, word has an annoying tendency to paste the diagram with the borders extending beyond the page boundaries, so if the .pdf method overcomes that, then that's a good thing!
Andy
« Reply #3 on: August 19, 2014, 09:19:03 am »
It's probably easier to use Project.SaveDiagramImageToFile ()
« Reply #4 on: August 19, 2014, 09:20:06 am »
ICR a method to copy the image to paste board via API.
Aaron B
« Reply #5 on: August 19, 2014, 09:44:57 am »
There is also the PutDiagramImageOnClipboard and PutDiagramImageToFile methods available on the Project Class which may be useful.
Stenvang
« Reply #6 on: August 19, 2014, 05:30:50 pm »
How do you initialize the project class to the current repository and how do you copy the image from clipboard?
« Reply #7 on: August 19, 2014, 07:45:40 pm »
You get it via Repository.GetProjectInterface(). How to get things out of the clip board you better ask on a MS forum (or on StackOverflow).
Stenvang
« Reply #8 on: August 19, 2014, 07:51:53 pm »
Thanks to all of you. Everything is working just fine now!
Here's a link to the solution I did come up with:
http://stackoverflow.com/questions/25358337/import-image-from-enterprise-architect-to-ms-word
« Last Edit: August 19, 2014, 10:49:02 pm by Stenvang »
« Reply #9 on: August 21, 2014, 10:35:45 pm »
I wasn't happy with the fact that my add-in would steal my clipboard (and I would loose whatever I copied before) so I figured out a workaround that first writes the image to a temporary file, then reads the file and then copies the contents into my document.
« Reply #10 on: August 21, 2014, 11:54:31 pm »
As you have already guessed, I'm no windoze programmer. But can't you push the current clipboard contents while doing the diagram operation and then pop it back?
« Reply #11 on: August 22, 2014, 04:01:25 pm »
I guess that would have been possible as well, but given the choice I'd rather not touch the clipboard at all.
