Author Topic: EA ignores registry values  (Read 14472 times)
Tehila1
« on: August 19, 2014, 11:51:18 pm »
Is there an addition location where the EA registry values are saved?
When I change registry entries, there is no effect on EA.
The registry I modified is EA400/OPTIONS -> VC_TIMEOUT.
Any ideas?
« Last Edit: August 19, 2014, 11:51:50 pm by avoda234 »
Re: EA ignores registry values
« Reply #1 on: August 20, 2014, 12:55:02 am »
There's a possibility that you looked in the wrong branch. Nowadays EA allows for storing values in HKEY User and Local Machine.
No idea which takes over precedence.
« Reply #2 on: August 20, 2014, 08:51:54 am »
EA will only read the key when it first uses it. After that it will cache the result. You're not trying to change it while EA is running are you?
Tehila1
« Reply #3 on: August 21, 2014, 04:14:40 pm »
I change it via an addin, so EA is running at the change time.
What do you mean in 'you have to use the key'? close and re-open EA or another meaning?
« Reply #4 on: August 21, 2014, 05:02:31 pm »
Then that's your problem. It will not work.
Tehila1
« Reply #5 on: August 21, 2014, 06:27:51 pm »
I tried to change the registry entry via a  stand-alone application, EA is not running. The result was the same - no influence on EA.
Any ideas?
RegistryKey currentUserRegistryKey = Registry.CurrentUser;
const string optionsSubkey = @"Software\Sparx Systems\EA400\EA\OPTIONS";
RegistryKey optionsRegistryKey = currentUserRegistryKey.OpenSubKey(optionsSubkey);
//Modify the relevant registry values. If the values were not found
//the program creates them with the right content.
Registry.SetValue(optionsRegistryKey.Name, "VC_TIMEOUT", "40");
« Last Edit: August 21, 2014, 08:32:20 pm by avoda234 »
« Reply #6 on: August 21, 2014, 11:32:44 pm »
Have you verified that the key was actually changed? I mean, did you look into the registry after running your program. Windoze often silently ignores those things and leaves you (like EA) in the believe that all is well.
Tehila1
« Reply #7 on: August 24, 2014, 06:48:16 pm »
Yes, I did.  The registry key was changed as expected, but does not affect EA.
How can I trigger EA to read the new value?
« Reply #8 on: August 24, 2014, 08:12:38 pm »
Could you tell me where in EA this value is set manually?
Tehila1
« Reply #9 on: August 24, 2014, 09:31:38 pm »
Of course: The appropriate location of VC_TIMEOUT registry key inside EA is:
Project -> Version Control -> Version Control Setting. At the bottom of the window there is a textbox named VC TIMEOUT Value.
Thanks in advance!
« Reply #10 on: August 24, 2014, 10:20:51 pm »
Ok. Found that. Now, how can I force the SVNserve to produce a time out? If I stop the server EA complains that there is no service at all. Is there a simple way to force it timing out? Would I need to setup some dummy service. And if so, on which port?
« Reply #11 on: August 24, 2014, 10:33:47 pm »
I did setup a dummy server and actually it worked. Changing the value in the registry made EA wait for the appropriate number of seconds as specified in the registry.
Tehila1
« Reply #12 on: August 25, 2014, 08:44:33 pm »
When I try to add a configuration to the VC_CONFIGS registry key, EA is not affected, and still "Requires configuration".
Any ideas?
« Reply #13 on: August 25, 2014, 11:13:44 pm »
Oh. This is a different thing. I thought you were just after the timeout not working. I might look into that later again.
« Reply #14 on: August 25, 2014, 11:35:17 pm »
You need to add a row to t_genopt:
AppliesTo=VCConfigs
Option=<VCConfigs><Config><Guid>test</Guid><Type>2</Type></Config></VCConfigs>
Of course you need to supply something else than test and if it's not SVN the "2" must also be changed.
« Last Edit: August 25, 2014, 11:35:49 pm by qwerty »
