Author Topic: Lock/Unlock element via AddIn  (Read 14752 times)
phdare
« on: August 29, 2014, 04:39:25 pm »
I tried to lock/unlock element via AddIn. In EA_OnContextItemDoubleClicked (before properties dialog is opened). I add some code to lock element
      EA.Element element = Repository.GetElementByGuid(GUID);
      element.Locked = true;
but it didn't work, properties dialog open and element isn't locked.
Re: Lock/Unlock element via AddIn
« Reply #1 on: August 29, 2014, 04:58:38 pm »
Your code misses the Update, but I guess you just did not post that. So most likely this will not work. There are already quite some work arounds in the area of these OnPre/Post methods since they do not exactly behave as you expect (some would call it inconsistency, but I just call it poor design). So I recommend to send a bug report and look for an alternative solution :(
phdare
« Reply #2 on: August 29, 2014, 05:36:57 pm »
If I add the Update method, I will get System.Runtime.InteropServices.COMException with message "Element Lock".
If I remove the Update, I need to close and reopen diagram afterward, the Element is locked. It seems element is updated without calling the Update. To walk around, I I add Repository.ReloadDiagram but it didn't work well, sometimes Sparx is crashed.
« Reply #3 on: August 29, 2014, 06:36:25 pm »
Locking and unlocking with the API functions doesn't work.
I've posted my workaround on the forum a while ago.
(use top left search button to search)
Viking
« Reply #4 on: October 18, 2020, 02:04:12 am »
Could somebody tell me the link, please? I cannot find the workaround. V.
« Reply #5 on: October 18, 2020, 02:32:05 am »
Element.ApplyUserLock() works if the element was not locked yet
And Element.ReleaseUserLock() works if the current user was locking the element.
For other stuff you'll have to manipulate the database directly.
Viking
« Reply #6 on: October 20, 2020, 04:34:35 am »
Many thanks, Geert. I am using these methods by still getting "System.Runtime.InteropServices.COMException" with message "Element Lock". Are there also other reasons for this Exception, e.g. a write lock on the database for any reason?
« Reply #7 on: October 20, 2020, 05:04:32 am »
In which circumstances do you get that message?
If you share your code we can maybe spot where it goes wrong.
