Author Topic: (BUG) - Stereotypes extending Port are fixed size  (Read 8391 times)
Svend Erik Nygaard
  • Business Information Architect
« on: August 29, 2014, 12:34:08 am »
UPDATE: Sparx has acknowledged this as a bug.
In my MDG I hav created some stereotypes extending the Port metaclass.
When we use these stereotypes, the elements are not manually resizable - just like original Port elements.
However, unlike the original port elements, these elements do not resize automatically when we add exposed interfaces to them.
Is there a solution to this (e.g. can I make them manually resizable or auto-resizable somehow)?
« Last Edit: September 02, 2014, 11:55:02 pm by svenderiknygaard »
Re: Stereotypes extending Port are fixed size
« Reply #1 on: August 29, 2014, 12:44:51 am »
Oh yes, there is. But I can't remember how  :-[
Unless someone else is faster you should read the help again. It must be buried there. Not sure if you find the right thread here in the posts.
[edit:]I actually meant this thread: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1344479419/7#7. But it is as clear as my above answer. :-/
« Last Edit: August 29, 2014, 03:53:27 am by qwerty »
Svend Erik Nygaard
Re: (BUG) - Stereotypes extending Port are fixed s
« Reply #2 on: September 02, 2014, 11:58:01 pm »
UPDATE: Sparx has acknowledged this as a bug:
"Our developers have confirmed that this is a bug and it is logged to be fixed. We cannot yet say when (in which build) the fix will be implemented."
"If necessary, as a current workaround you can right click the Port, select 'Port Size Customizable', then manually resize the Port."
