Author Topic: Re-using script fragments  (Read 5069 times)
Jayson
« on: September 01, 2014, 11:38:18 am »
Hi all
I've got some script fragments in VB script that I want to reuse in several larger scripts.
I've looked at how the included scripts do it and they seem to use the INC statement.
So, I have created two script files.
File #1
This includes a main sub plus:
In the header
!INC Jayson.TestScript
Plus in the main sub
TestScript.SayHello
File #2 is called TestScript and is in the Jayson folder.
It has a simple sub as follows:
sub SayHello
    MsgBox("Say Hello")
end sub
What I expect to happen is execute file #1 and have a message box saying "Say Hello" appear.
What I DO get is an error message in the second file stating:
Jayson.TestScript error: Expected statement, Line 1
So, it would appear that the script engine is trying to execute the SayHello subroutine, but is failing.
Any ideas as to what I am doing wrong?
Cheers
Jays  :)
Uffe
Re: Re-using script fragments
« Reply #1 on: September 02, 2014, 08:11:26 pm »
We meet again! :)
Is that the whole of Jayson.TestScript? Because you get that error if the included script starts with option explicit. In other words, you need to decide beforehand whether a script file is for execution or inclusion, and place option lines only in the former (check out Local Scripts.EAConstants-VBScript; no option lines there).
This is because the !INC statement has the same(ish) semantics as a CPP #include, rather than a Java import: a textual inclusion, not a namespace reference.
For the same reason, it looks as if there's an error in the "main" script as well. Just as you don't specify a namespace for the MsgBox() reference, you shouldn't specify one for SayHello().
/Uffe
« Last Edit: September 02, 2014, 08:13:01 pm by Uffe »
Jayson
« Reply #2 on: September 03, 2014, 05:37:16 am »
Thanks for that Uffe!
I'm about to wander off for a long weekend away, so I will give this a shot next week.
Jays :)
