Author Topic: Program inside report templates  (Read 4577 times)
MoonRider
« on: September 12, 2014, 12:49:41 am »
Is there a way to kinda program inside report templates?
I ask because I want to add the included usecases to the report, but it only appear as connector.. I wish to make a separated table to this.. but I would need to test something like:
if ({Connector.Type}=='include'){ display: target>element> {Element.Name} <element<target}
for example.
Is there a way to do that?
robinch
Re: Program inside report templates
« Reply #1 on: September 12, 2014, 03:58:54 pm »
You could use a template fragment with a custom script fragment.
I had problems in the past with custom script fragments due to a size limitation on the XML output from the script. IIRC, this limitation has been fixed in one of the 10xy builds.
