Author Topic: Linking to class member functions  (Read 4086 times)
Wade Brooks
« on: September 18, 2014, 06:38:20 am »
 I have a requirement linked to a class, I then used the  "link to element feature" to link it to a class member.  The automation interface shows it is linked to the class.   How do I find what member function it may be linked to.    And how do you link to a member function inside a class with the automation interface?
Re: Linking to class member functions
« Reply #1 on: September 18, 2014, 08:11:18 am »
The API does not offer a direct method for this. EA creates an entry in the StyleEx property of the Connector object. For an association this is
LF<dir>P=<guid><pos>; connector is attached to attribute/operation
<dir> = S or E meaning Start (source) or End (target) <guid> = ea_guid of t_attribute or t_operation
<pos> = R if <dir> == S or L if <dir> == E
<pos> is obviously redundant...
There can be one LFSP, one LFEP or both be present in one StyleEx property
(from my Inside book p. 51)
« Reply #2 on: September 18, 2014, 03:52:18 pm »
Linked elements are one of the things you can navigate to in my EA Navigator addin.
Here's the code that does the magic from ConnectorWrapper.cs
private UML.UMLItem getLinkedFeature(bool start)
          string styleEx = this.wrappedConnector.StyleEx;
          string key;
          UML.UMLItem linkedFeature = null;
               if (start)
                key = "LFSP=";
               }else
                     key = "LFEP=";
               int guidStart = styleEx.IndexOf(key) + key.Length ;
               if (guidStart >= key.Length)
                string featureGUID = styleEx.Substring(guidStart,this.WrappedConnector.ConnectorGUID.Length);
                linkedFeature = this.model.getItemFromGUID(featureGUID);
          return linkedFeature;
The getItemFromGUID operation from the Model.cs looks like this:
     /// <summary>
      /// finds the item with the given guid
      /// </summary>
      /// <param name="guidString">the string with the guid</param>
      /// <returns>the item that is identified by the given GUID</returns>
        public UML.UMLItem getItemFromGUID(string guidString)
              try
              UML.UMLItem foundItem = null;
              foundItem = this.getElementByGUID(guidString);
              if (foundItem == null) foundItem = this.getDiagramByGUID(guidString);
              if (foundItem == null) foundItem = this.getAttributeByGUID(guidString);
              if (foundItem == null) foundItem = this.getOperationByGUID(guidString);
              if (foundItem == null) foundItem = this.getRelationByGUID(guidString);
              return foundItem;
              catch (System.Runtime.InteropServices.COMException e)
                    if (e.Message.Contains("Can't find matching ID"))
                          return null;
                    else
                          throw e;
You can either use these pieces of code, or you could choose to use the EA Addin Framework as a whole. More about that on How to use the Enterprise Architect add-in Framework
