Author Topic: Adding SysML Value Properties through the API  (Read 4912 times)
sherey
« on: November 04, 2014, 08:45:30 am »
Using the API, I am able to add all sorts of things to my SysML blocks except for Value Properties.
I see in the reference model in the help that you can't add Custom Properties to elements.  But when I read my value properties from the api, they are listed in the elements and embedded elements collections of the block, not the Properties or Custom Properties collections.
Is there also a restriction on not adding SysML Properties as elements?  Or is there a different object type besides "UML::Property" to use in the AddNew method?
Thanks!
Re: Adding SysML Value Properties through the API
« Reply #1 on: November 05, 2014, 09:04:57 am »
Instead of UML::Property, try UML::Part
sherey
« Reply #2 on: November 06, 2014, 05:02:06 am »
UML::Part didn't work, but "Part" by itself worked.
I want to define a stereotype in my custom profile that is created as an extension of part.  However, I don't see "Part" in the metaclass list. It isn't even listed as a stereotype in the SysML 1.3 MDG.  Do I make my stereotype an extension of "Object"?
« Last Edit: November 06, 2014, 05:26:12 am by sherey »
« Reply #3 on: November 06, 2014, 08:02:30 am »
There are (have been?) some elements not in the list which you could type manually, though. That might be one of those candidates.
