Author Topic: Version 3.50 - Build 581 released  (Read 24891 times)
sparks
« on: November 21, 2002, 04:12:14 am »
Changes in Build 581
- Fixed problem with toggling line point on custom line with connector lines at some angles
- Fixed problem when dragging element from tree onto diagram with modified connector positions, state. Connector state now retained after drop operation
- Modified handling of dates in SQL Server for some non-English formats
- Modifed deletion of connectors in SQL Server ... problem with association classes in some instances.
- Fixed problem with generation of collaboration message documentation when using MySQL
- Fixed problem with line continuation characters in VB parameter lists
- Added support for indexers to C# code parser and generator
- Added support for operator overloading to C# code parser and generator
- Added support for 'dotted' method names in C#
- Fixed problem with color toolbar 'style drop list' not working correctly
- Fixed problem with backspace and \ key not navigating thru 'locked' diagrams
- Fixed problem where note and text elements could show & as _
- Added check before locking diagram .. if diagram is 'dirty' message box pops up with chance to save or cancel before locking
