Author Topic: Importing Model  (Read 5006 times)
minna
Importing Model
« on: November 11, 2014, 11:35:41 pm »
I have a .eap project (A) with only one model. I want to import this model into a version controlled .eap project (B) with 5 existing models.
I tried exporting the new model (A) to .xml and .xmi using both XMI 1.1 and 2.1. When trying to import it into the existing project (B), I get a error saying there is an error with code 0x80004005, error description is unspecified.
Am I doing it wrong? Is there an error when I export the model into an .xml / .xmi file?
Minna
minna
Re: Importing Model
« Reply #1 on: November 11, 2014, 11:48:04 pm »
When looking at the error, it says there is an error in line 441589. When looking at that line, it looks like the last characters are all squeezed together, like some bug corrupted that line.
Even if I create a new .xmi / .xml file, the error is still there. Why does Enterprise Architect create this bug when creating an .xmi  / .xml file?
Any help is appreciated.
Minna
Re: Importing Model
« Reply #2 on: November 12, 2014, 12:17:01 am »
You should contact Sparx support/report a bug.
You "could" try to correct the XMI manually with an editor which might import most of your model - but not everything correctly.
