Author Topic: Can't remove quick linker  (Read 15276 times)
Jayson
« on: November 19, 2014, 04:35:09 am »
Hi all
I am having a problem removing a quick linker from my MDG, so am wondering if anyone else has struck this problem and if so, how to fix it.
I decided to remove one of the entries from my quick linker file.
I rebuilt my MDG and when I fired it back up, I expected the option to no longer be available when the user drags the quick linker away from the element in question.
Unfortunately, it is still there  :o
Has anyone struck this and if so, any words of wisdom on how to fix it?
Thanks in advance
Jays  :)
OpenIT Solutions
Re: Can't remove quick linker
« Reply #1 on: November 19, 2014, 04:55:55 am »
I'm sure you checked - but doesn't the quicklinker have two entries for each element - source and target, depending upon context when linking - did you remove both entries ?
Jayson
« Reply #2 on: November 19, 2014, 05:05:32 am »
Hey there, nope it doesn't.
I did a search for the name of the connector type and it comes up blank also.
Cheers  :)
« Reply #3 on: November 19, 2014, 05:23:36 am »
With search you mean "search in XML/MDG"?
Jayson
« Reply #4 on: November 19, 2014, 05:25:05 am »
Hey Q
I've searched in both the linked document and the resulting profile, both with no success.
Cheers  :)
« Reply #5 on: November 19, 2014, 05:28:17 am »
Ah, forgot: maybe the QL for that element is something which is there per default (as being inherited from base UML or so).
Jayson
« Reply #6 on: November 19, 2014, 05:31:26 am »
Hey Q
The connector being created is a stereotype I created.
Whats worse is that I have since DELETED that stereotype, but it is STILL driving me nucking futs!
How on earth can my users create a connector that no longer appears in the MDG with a quick linker that likewise no longer appears in the MDG?
I might try a re-boot of the machine in case there is some kind of bizarre caching problem
« Reply #7 on: November 19, 2014, 09:20:11 am »
That wouldn't be necessary, but depending on what version of EA you are using, you may need to restart EA. Also check that your profile/technology isn't loaded more than once. And check that you rebuilt your technology after re-saving your profile.
Jayson
« Reply #8 on: November 19, 2014, 10:11:08 am »
Hey there
Yep, I have re-saved the profile and re-built the MDG (several times).
I also checked to make sure I am pointing to only one version of the MDG.
Weird!
Cheers  :)
« Reply #9 on: November 19, 2014, 09:26:01 pm »
Is it repository dependent? Same issue with a clean EAP?
Jayson
« Reply #10 on: November 20, 2014, 03:40:41 am »
Hey Q
I hadn't thought about trying that.
But yep, I just created a clean repository and the old quick linker still raises its ugly head  >:(
Jays  :)
« Reply #11 on: November 20, 2014, 05:06:40 am »
In that case: where is your MDG? Have you stored it in the EA program folder additionally to some Advanced file location from the MDG dialog?
Jayson
« Reply #12 on: November 20, 2014, 05:23:40 am »
Yup, I place my MDGs in a folder and then point to them using the advanced option.
« Reply #13 on: November 20, 2014, 08:53:40 am »
Have you cross-checked program files \Sparx Systems\EA\MDGTechnologies ?
Jayson
« Reply #14 on: November 20, 2014, 09:00:57 am »
Hey Q
Sorry, not sure I understand.
What do you mean by cross check?
Cheers  :)
