Author Topic: creating a new model based on an mdg through API  (Read 3357 times)
sherey
« on: December 05, 2014, 07:16:18 am »
How would I use the API to create a new model based on a Package Structure stored in a MDG Technology?
I see the repository object's CreateModel method, but CreateType is 0 for the standard EA Base model and 1 to create through an SQL connection.
If just create a base EA Model, I'm not seeing another method that creates root based on a package structure in an MDG Technology.Do I use CustomCommand("Repository", "ImportRefData", <xml>)?
Thanks!
Re: creating a new model based on an mdg through A
« Reply #1 on: December 05, 2014, 07:47:22 am »
I guess you can't do that. Unless you read the MDG, interpret it, and build the structure based on that. You could probably ask for a new feature. Can you hold your breath for a couple of years?
