Author Topic: Replacing AS-IS elements with TO-BE elements  (Read 3404 times)
phokanson
« on: December 10, 2014, 01:01:56 am »
Does anyone know of a script that replaces an element with another updated element?
We maintain two trees of project models (all within the same project database).  One tree holds the current (AS-IS) model state that is in production.  The other tree holds the models that are in redesign (TO-BE).  When the redesign models have been approved, we want to replace links with in the AS-IS tree with the updated elements/packages in the TO-BE tree.  If there are just one-zee, two-zee, replacements it's not too bad.  However, we've had several project (an numerous coming up) where many elements/packages will need to have updated links.
Re: Replacing AS-IS elements with TO-BE elements
« Reply #1 on: December 10, 2014, 03:19:22 am »
IIRC Stefan Bolleininger has published his merge script here a while ago.
