Author Topic: Add Diagram Notes element to diagram  (Read 7018 times)
coatie
« on: December 23, 2014, 01:53:35 am »
is it somehow possible to add the "Diagram Notes" element (the element showing author, created date, changed date and version) to a diagram using the automation interface?
I prefer using the "Diagram Notes" element instead of using the "ShowDetails" properties since the "Diagram Notes" are relocatable.
Best Regards,
Markus
Re: Add Diagram Notes element to diagram
« Reply #1 on: December 23, 2014, 02:35:56 am »
Try Diagram.ShowDetails. Setting it to 0 or 1 will turn the details off or on.
Aaron B
« Reply #2 on: December 23, 2014, 09:35:07 am »
Here is a simple JScript example which creates a new Diagram Note element and adds it to the current diagram:
!INC Local Scripts.EAConstants-JScript
function OnDiagramScript()
      // Get a reference to the current diagram
      var currentDiagram as EA.Diagram;
      currentDiagram = Repository.GetCurrentDiagram();
      var currentPackage as EA.Package;
      currentPackage = Repository.GetPackageByID( currentDiagram.PackageID );
      if ( currentDiagram != null )
            var diagramNote as EA.Element;
            diagramNote = currentPackage.Elements.AddNew( "", "Text" );
            diagramNote.Subtype = 18;
            diagramNote.Update();
            var dobj as EA.DiagramObject;
            dobj = currentDiagram.DiagramObjects.AddNew( "", "" );
            dobj.ElementID = diagramNote.ElementID;
            dobj.Update();
            Repository.ReloadDiagram( currentDiagram.DiagramID );
      else
            Session.Prompt( "This script requires a diagram to be visible.", promptOK)
OnDiagramScript();
« Reply #3 on: December 23, 2014, 09:58:30 am »
Oh. I mixed that up. The diagram details is fixed top left and has fewer information.
coatie
« Reply #4 on: December 24, 2014, 05:19:30 am »
Thank you very much Aaron!
Any chance to also set the option "Scale to one page" for a diagram via the automation interface?
« Reply #5 on: December 24, 2014, 09:48:03 am »
You need to check the string value of Diagram.ExtendedStyle and look for ScalePI=<flag>; where <flag> is either 0 or 1.
« Last Edit: December 24, 2014, 09:48:57 am by qwerty »
Aaron B
« Reply #6 on: December 24, 2014, 10:43:16 am »
Yep, what qwerty said.
ExtendedStyle contains a lot of different options in a semi-colon delimited string.  Make sure to check for any existing "ScalePI" value and careful not to lose any other settings when updating the string.
